Installed and unistalled roller. Now won't frame
I have the Ortur roller rotary. I installed it and used it a couple days ago. Today I took it off the machine, and unclicked Enable Rotary. I also reloaded the machine settings that I saved before the rotary was added. Now I cannot get frame to work. When I click it I get ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 0:
Stream completed in 0:00
There are no objects outside the work area. Start from is set to Absolute Coords.
I have jobs waiting. Please help!!
In console type
$RST=*
Press enter
press enter
Post the output here please.
Did the $RST+*. It will now frame.
Did $I.
S#
error:2
Numeric value format is not valid or missing an expected value.
$I
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[MODEL: Ortur Laser Master 2 Pro S2]
[OLF: 185]
[OLH: OLM_ESP_PRO_V1.2]
[OLM: GENERAL]
[DATE:22:44:33 - Oct 25 2021]
[VER:1.1f(ESP32).20210403:]
[OPT:VNMZHSL,35,4096,3]
Target buffer size found
ok
So your firmware is quite old
$RST=*
Press enter
when laser says “MSG: restoring defaults”
Tap reset button on motherboard.
Then upgrade the firmware to 191.
Firmware section
That seems to have corrected my issues. Thank you!
