Installed latest upgrade now nothing works
100% a shot in the dark given the fact that you’ve really given no data, but maybe your config got corrupted during the upgrade. Might try doing a File/Preferences/Load Prefs Backup. Select one of the config backups from prior to your upgrade and load it. May or may not work, but WAY more information will be needed for anyone to give suggestions from here.
Thanks Steve
I have found the problem.
The upgrade had removed all my settings including the laser, i had to reset everything.
I thought my laser had gone down but the software had defaulted to CO2, mine is a diode…phew.
The process I noted would have restored everything. LightBurn makes many backups of your configuration files. The process outlined is how to restore one of those backups, and not have to recreate everything.
