Installing LightBurn with a Laser
Can Lightburn Software be installed and used without actually having a laser Burner connected to Laptop ? I want to test and use software before a I buy a laser burner … Thanks in advance…
-Jorge Saenz
I’ve used it without being connected to any device…
So, I’m sure you can also… The trial is a relatively short period, and you should probably wait until you order the machine with an expected delivery…
I assume you will get a Lightburn compatible laser of some type…?
Our documentation is worth review. Yes, you can set up as you describe. :slight_smile:
What if I don’t have a laser yet?
