Just want to make sure I’m clear on this. I’ve read several other posts but I still am not sure.
Question: When you import an image and set it as pass through, several of the settings are grayed out, including line interval (in) under image settings. In the cut info window interval (in) is not grayed out.
Are these the same settings? And if so, if I change interval (in) will it resample the imported image even though its set as pass through?
Thanks very much
Pass through means the interval value is completely ignored, and computed at the moment the image is processed for output.
You can un-tick the pass through button and change the interval value, then re-tick pass through. It will have no effect whatsoever, other than changing the number you see on the screen.
