I am using an Orthur 2 Pro with the ORTUR Laser Rotary Roller. If I detach the rotary roller the text prints normal. If I attach the roller it is printing inverse/mirrored. I am new to the software and to this burner. I have checked the settings and checked where the home corner is. For me it’s in the bottom left and the settings reflect that. Any suggestions?
Is the burn also rotated? Or just mirrored.
Could you just rotate the rotary 180 degrees? Else have you tried the “Mirror output to Rotary” option in Rotary Setup?
