As topic says the image invert in the adjust image window. I can select it and it shows the image as inverted. Once i click save it does not change the image to inverted
What’s your end goal?
“Invert display” will invert the display for viewing only and does not change the actual output. “Negative Image” indicates that the image should be treated as a negative and will have consequences on the output.
I am wanting to burn a image on slate and with testing i have seen i need to make it negative like. So i have tryied each setting (negitive image) & (invert display which i know does nothing normally)
Are you saying this does not actually invert the areas to be burned? Check this in Preview but making sure that you’re not re-inverting the display. Otherwise just run a couple of small test burns one where “Negative Image” is enabled and one where it’s not.
