I’m super new to all of this but googling around didn’t really help me. Red outline on the image is supposed to cut, the blue design is supposed to be filled in but the laser is filling in everything that’s supposed to be blank. How can i invert this?
Drawing a box around it helps but then it basically puts the image into a big black void, and it’s really important for this design to have a clean cut outline. It’s probably super obvious, but can someone help me? Thank you
Thank you! I saw these tutorials but maybe i’m not following along properly? Offset is probably what i’m looking for but it does create a thick dark outline around the object that i don’t want. I made a small test image where it’s looking exactly like what i want but somewhere along the whole outlining and splitting the image i made some critical mistake ![]()
Other than the outline being burned because of wrong settings, this is what i’m going for. This is the lightburn file (sorry it’s all german..)
rauhaut laserdatei.lbrn2 (1,9 MB)
Check if it is correct.
rauhaut laserdatei_191115.lbrn2 (2.1 MB)
How I use LightBurn: enable Filled Rendering and jog with Layer Mode.
If you want to switch between Filled - Wireframe just press Alt + Shift + A.
This helps me with showing it in the editor correctly! But it sadly still doesn’t change the output of it being all filled in where it’s supposed to be blank and vice versa.
Sorry missed the pic.
rauhaut laserdatei_1_191115.lbrn2 (1.9 MB)
The Cut Layer is crossing the Red Layer in some parts, is that intended?
For the cut do multipass or use sub-layers to reduce/eliminate scorching.
The output is still filled in.
I made this to really explain what i want, as the final print:
I want this shape engraved and then perfectly cut out around the outline, but the second i add the outline as it’s seperate layer it inverts the inside details
The outline must be in another Layer or it gets the blue Layer Mode ( Fill )
Yes but when its in another layer the stuff inside gets inverted. I really don’t know how else to explain it, but compare the preview images to my test piece.
Ok. I traced (C01) the image, offset the outline set to C02 and draw an auxiliary square with one side at the middle of the shapes to get what your trying in a faster and easier way.
Set C02 to Fill mode so that when you apply the Cut Shapes Tool the shapes are kept filled.
Try yourself the shapes that go with the file:
rauhaut laserdatei_1_191115_Cut_Shapes.lbrn2 (3.8 MB)
I suggest you have a read at the docs:
Something wrong, not the Preview I have:
You can see the cut and the fil
You are trying with the original file
where the cut crosses the fill.
Test with this one:
Oh that’s perfect, thank you!! I chose the wrong bat for the preview, thank you so much for fixing it!
Even tho you wrote what you did i don’t think i’m doing it correctly because i can’t replicate it.. Maybe it’s a language barrier, what do you mean with offset the outline? Your version is exactly what im trying to do
Oooooooooh i got it i got it, ah you’re wonderful thank you very much! Okay i actually get it now ![]()
