I have one project that consists of 8 layers of cardstock or thin plywood. Once cut, each layer (which have the exact same circular outline) will be stacked together to form an image. To give you an idea, the back layer is solid, the next layer has the setting sun, followed by mountains, mountains again, a couple layers of trees, etc.
Should each layer be a separate Lightburn project (that generates separate g-code for the single layer) - OR - can I create one file with multiple layers (each one corresponding to a layer of material in my project) and generate g-code for the project that will stop in the middle and allow material to be swapped? (or, can Lightburn generate g-code for a single layer of a project?)
