Is it possible to lower power on the second pass?
I’m trying to cut a shape and the shape cuts 99% with 100% power and on the second pass it cuts all the way. I don’t need 100% power on the second cut. Is it possible to increase the speed or cut with lower power on the second pass?
Not if you select 2 passes in the Cuts window.
Select the path, do a CTRL-D (to make a copy), assign that to another layer, and lower the power or up the speed on the second layer.
You might be able to use sub-layers, but I have not played with that yet.
Sub-layers:
  • First -Layer (your set speed /100% 1 pass)
  • Second-Layer ( your set speed / <100% 1 pass)
