Is it safe to Update XTool S1 Firmware?
Back in May someone posted that their XTool S1 stopped working properly after a firmware update. The response was that XTool had probably made changes that caused the problem. I have been holding off doing a firmware update until this problem has been resolved. Has this problem been corrected in Lightburn and is it ok to update my S1’s firmware.
If I read your post correctly, it’s not LB you should be asking about that, but your machine manufacturer.
I got an S1 a couple weeks ago. As is my usual pattern with tech, I updated it to the latest firmware before trying anything else.
There have been some small issues with the Lightburn early releases that I think are Lightburn issues, but overall I saw no problems with the S1 firmware. I have tried the XTool Studio software, too, in part to make sure the laser was working as expected.
bernd.dk … In no way do I believe that Lightburn the cause of the problem. Anyone who owns an XTool Laser knows how they are very reluctant to share any information with anyone including the developers of Lightburn. Anytime you do a firmware update to an XTool machine you hold your breath wondering if it will still work with Lightburn. The Lightburn development Team has been great in their efforts to correct issues that new XTool firmwares have caused. I am merely trying to find out if the latest XTool S1 Firmware update is causing new issues, and if so has the Lightburn Team found a solution to the problem.
Thanks for the clarification, I hope it works out for you in the end.
OK, so I went out on a limb and upgraded to the latest firmware and all is good.
