Is lightburn crippled after 12 months if you don’t upgrade?
I ask as I have an Atomstack X20 that will only cut 7mm in softwood (cls) and I wondered if it stops you using full power??
The only thing you lose is the ability to update to newer versions
The last vesion you have enabled will work forever
Stays 100% fully functional, you simply can’t update to the newer versions after your 12 months of updates runs out as explained here:
