Hi,
Wondering if there is a bug with kerf offset per layer??
I am cutting a file that has interlocking ends, it is my last layer cut. I tested cutting just that profile line layer and set the kerf offset how i wanted for a tight fit.
All previous layer line cuts have kerf offset of 0.
When I select all and cut…my profile with the kerf offset that i set…is now way too loose…i’m wondering if the kerf offset is being ignored…or what is happening?
Anyone else experienced this?
thx
If I’m following you, then the layer should be handled as a layer – even grouped with other layers.
I believe I’ve done this a number of times…
If it’s broken, can you provide more information?
Good luck
I’ve done a small test, using just a portion of the file i was cutting and it worked fine doing the test…unsure what happened here. I will be recutting the full again and can compare against the test…Shouldn’t be any different, multiple layers and settings the same still.
Unclear why i was getting this result.
found the issue…path wasn’t closed…should have thought to always check that first.
Autojoin and close path did the trick.
