I have purchased a product and for whatever reason the “belts” were not the correct size for the project so I went through and modified all of the holes in the belt see the first attached image
That worked out for me very well and now my pieces fit the holes with out issue, but I quickly realized on assembly that the SLOTs do not match the holes and to make it more of a challenge one of the slots is larger than the rest. Is there a way for me to widen the slot the same width as the hole?
Thanks,
Ron
You can probably use the Resize Slots in Selection, found under the Tools menu. You need to know the current dimension of the slot in order to use it. Shoud work, see docs.
Right after I submitted the question I did search slots and tabs and YES! It works like a charm! Thank You for the prompt response and I promise next time to search BEFORE posting a question!
