Is there a way to label the layers, rather than just the 2 digits?
It would be great to be able to label these, even if it was a popup when hovering over it. Is there a way?
If you double click on the layer in cuts/layers panel it brings up cet settings editor. You can change the name there. After naming it there, when you hover over the color on the bottom it pops up the name.
on my particular Cuts/ Layers window, there is a # column next to the layer column that shows the name. Don’t see how to turn it on or off, maybe a galvo thing?
Thank you very much!
