Is there a way to set scroll interval?
When using the mouse wheel to change values in various fields, the jump is, for example, 0.5 for camera shift/size settings, but sometimes it is desired to have a 0.1 advance. Some of the other fields that support mouse wheel changes have similar actions, a larger than minimum allowed change per mouse wheel movement.
I’ve discovered that holding down the control key (windows) increases the increment, but other key modifiers does not decrease the increment.
Am I missing something or is this a fider.io kind of request?
That would be a request, yes. Arrow keys and PgUp/PgDn likely do the same as wheel / shift+wheel. I expect I’d have to custom code additional keys.
