Is there a way to turn off all changes to settings?
Mostly changes to power and speed. I turned off default in settings but it still changes power and speed when I need to do several of the same pieces.
What do you mean? If you save a project and then open it again, the settings change? → Make sure you open the project, do not import it.
You can choose whether all layers are set to defaults on every start of LB / new project. But this won’t affect already created projects.
OK I will open rather than import now. Thanks
