Will not frame right on two projects that are completely the same. The color palette is completely gone. you do not want me to rate this software is the last 4 months. Maddening
I have no problems at all.
Framing works fine for me. Are you sure there are no artifacts somewhere you can’t see?
If the color pallet is gone, you do have the option under window to turn it back on.
Oh, threats usually do not get you much help. Ask about your problem in a nice way.
I’ve found when a project isn’t working well it’s usually a matter of me not using the right tools or the right materials or often using the right tools on the right materials but using them the wrong way. Lightburn (the tool in this case) is a complex item with many parts designed to do many things. Without a good understanding of all the parts and all their functions using Lightburn will be a frustrating experience.
Same project same everything laser was not even moved
In order to help others, there must be a clearly defined problem.
It helps a lot to show examples in the form of images or files of the project itself with your settings or at least a detailed description of the problem.
It is absolutely useless in this context to ask if others have the same problems when you don’t even seriously try to describe what it is about.
For your headline, everyone could just write - no.
I find most often it’s Pilot Error. Be patient and assume straightaway that additional student flights (into the manuals) are needed before going on your solo jaunt into an area of Lightburn you’ve not traveled before. Frustration is a very crippling ailment. It will steal your desire to find a solution. There is always a solution. Don’t get locked out of enjoying your new tool because of anger. I suggest also that you do not set it aside. Start a methodical search. So what, if it takes two or three weeks. Eventually, it all will be solved and you will have the pride of accomplishment. Hang in there kid, and stay frosty.
Sometimes it falls off the bottom of the screen.
You can reset the display and menu set up by holding the shift key when LightBurn is starting.
Let’s get that back and then talk about what might be holding you up in framing.
