Is there anyway to force sub windows to open on a specific monitor
LightBurn always opened sub windows (like the preview, device setting, machine setting) on the same monitor where the main LB window was displayed. I recently added an additional monitor to the PC and now the sub windows open on a different monitor. This is not a huge problem, but it would be nice if I could get them to open on the same monitor as LB is on. This may be a more general Windows question than a LightBurn question.
I am running 2 monitors and haven’t seen an issue with it. Try putting the tabs back where they belong in the lightburn window and then close the program. When you restart lightburn, hopefully, all will be as it should.
Windows remembers which monitor to use when running a specific program. It will restart that program on the last monitor it was used on.
