Is there away to work on multiple projects without having to click lightburn again
is there a way to have a tab system were i can easily switch between projects?
It is a much requested feature. See
https://lightburn.fider.io/posts/639/project-tabs
Add your vote for this feature.
There is a workaround that I use. I open multiple LightBurn windows and work in them, switching between windows as the need arises.
But the first window seizes the USB port, denying them to the other LightBurn windows. If I wish to burn in another window that was opened later I switch to that window, unplug the USB cable and then plug it in again. A new USB entry is created in the Devices list and I choose that entry. Now I can burn that project.
It is a minor hassle but it works for me. I don’t know how this will work with saves to the art library and material library where conceivably there might be conflicts.
What I like about this is that I can easily copy and paste between projects.
