Issue exporting to SVG after updating to 0.9.18
Is anyone else having trouble when exporting to a SVG after the update?
When I export a design only the outer edges of the design appear to be exported in the svg file. I’ve tried grouping and ungrouping the vectors and changing the layer in LB but get the same result. This is a vector I’m using from a library I created awhile ago and its exported fine in the past. I just updated to the latest version this AM and now I’m having this issue.
Any suggestions on what to check? TIA
SVG_ISSUE
I just installed the previous version and the export to SVG function worked as expected. Something is up with the new version!
I have Ver 0.9.18 and I can not recreate this issue. SVG’s export correctly for me. Can you upload the LightBurn file you are having issues with?
Its not a separate file, I was using a vector image from an art library I created in LB. I’ve reinstalled the previous version of LB and its working fine. I’ll try updating the the latest version again later today and see if the issue returns. It may have something to do with the art library and updating to the new version.
We have a fix for this for the next release.
Great,
When I went back to the previous version one of my art libraries is acting up now. The icons in the library don’t match the actual vector when I add them to a new project. If I create a new library it behaves as expected but at least one of my previous library files is like this.
Any idea when the next release is planned?
I hope it is soon
