When I look at the size of an object, this height is a little bit bigger (24.88 mm) than the size of the segment (24.5). why?
This is a problem for me because I trust the size of the object usually to make my build
Hello Cierniewski,
Is it possible the peaks of all the semicircles are slightly different?
Would you be able to share the LBRN so we can take a look?
Thank you for your answer. I found the problem. the bottom line was actually a very slight curve
