I have encountered an interesting issue.
When I load up a file for the Falcon 2 in the latest RC3 and select Frame the laser goes to the Y limit and errors out rather than framing properly.
Full sequence: The laser is homed first.
When I hit Frame the laser moves to the proper starting X/Y point then to the right in the X direction to proper right frame edge then moves toward the back in the Y direction. However, instead of stopping at the back right corner then moving left it keeps going past the Y frame corner point and hits the Y end stop then errors out.
If I exit out of LB and reload the file it starts framing normally in most cases but sometimes requires two or three reloads for it to start working properly. After it frames properly it burns the job with no issues.
RC3 is a REALLY old build and we’ve already released the full 1.7.01: Index of /LightBurn/Release/LightBurn-v1.7.01/
Please use that version. If it’s still an issue, let us know.
Wow, apologies, I thought 1.7.01 RC3 was a recent release…
I have installed 1.7.01 and everything seems to be OK so far.
Thank you!
