Attempting to install a camera on my machine (omtech 50w) I have it physically installed fine, but am running into issues with the alignment.
The live view is showing fine, but when I hit capture, it’s just showing a greyed out image, it did this on some of the images for lens calibration too, but it still claimed to have found the pattern and let me continue, which implies the image is there but not displaying correctly.
Using Windows 11, any suggestion? I’ve tried this using both default and custom camera settings.
Make sure you have granted LightBurn permission to access your camera in your system settings.
Yep, done that too.
When you hover over your camera in the camera control window what tool tip do you receive?
You should be capturing an image for every step of the lens calibration process, not just some.
What version of LightBurn are you using and what pattern are you using to calibrate your camera?
Resolution 3264x2448, Calibrated, not aligned
I think it’s capturing an image, it’s saying it’s found the pattern and rated it, just not displaing the image.
Using AprilTags and LB version 1.7.08
Thanks for answering my questions. I would be interested to know if you get the same results using our new release candidate, which includes camera calibration improvements:
Was the camera included with the laser? Does your laser manufacturer provide specific instructions for using the camera in LightBurn?
Still no luck with the 2.0 release candidate, just to check, I presume that the capture should be showing some form of image even if it’s not detecting the pattern/target for allignment?
it’s a 3rd party camera and doesn’t have specific instructions for lightburn.
