im having an issue with using speed/power change during a burn. it seems to alter the size of the of the project. Ive provided a pic to illustrate. hmm i guess im too new for that right. anyhow im trying to burn a checkerboard into basswood sheet and i noticed it burning quite deeply i tried to back off the the power. i came back few moments later it cut the square down to 2/3 size and started to burn next row of boxes. im relatively new (obvious, sorry) and im trying to figure out if its a glitch with xTool machine communication or Lightburn itself? i hook up to xtool d1 thru my computer via usb cable and that can be an issue also. i just thought i could get a quick answer here before i move to xTool. Ive tried to enter as much info as i thought be needed please forgive me if im lacking as adding pics i could supply more.
xTool and Lightburn has had a rocky relationship and there has been more than a few odd problems. I would say this might be another, but not an expert on this.
What @Dskall is saying is that xTool uses a proprietary form of GCode, but does not share any detal with Lightburn. The Lightburn team has to figure it out on their own, and release an ,lbdev file to the users. xTool will then poste that file on their website, and then change the code and not share the new changes.
It appears xTool cares nothing about Lightburn, and prefer you use their software (XCS?) instead.
Let us work with you here to make sure it is not just a design or settings issue. If we can’t sort it out, then everything we learn here will be available to the developers.
I will start off with: Can you upload your .lbrn2 file so others can examine it?
I pulled this off their website, implying no issues. I admit, they have the prettiest website I have seen in a long time. I hope their web developers get paid well!
.lbrn2 = This is the project file you save as your designs. .lbdev = This is a file the manufacturer supplies (supposed to, anyhow) that sets up the machine information settings to allow Lightburn to control it properly. It seems xTool owners have better luck if the file is provided by the Lightburn team. It is important Lightburn knows which model machine you have (xTool D1 pro).
It does not come with Lightburn. You would normally download it from xTool.
Not for this issue. Try to find the .lbdev on the xTool support website first. It took me no time at all to find this.
I opened up your backup file (removed the _backup part) and it appears to have most of what you were working on. With a simple change in the Cuts Editor page, I got the run time down from 53.5 minutes to 41.2 minutes, for a time savings of 23%.
If that caused that offset in row #5, then I am guessing your xTool does not like the commands sent when changing speed. I do not know what Lightburn sends, but apparently when you reset to the original speed, it cancels the offset issue. Totally strange…
Step #1: To see what is going on, turn on Show All in the Console window. Then run a simple program. If it shows all the GCode commands being sent to the controller, then go to Step #2.
Step#2: Clear the Console window (right click). Create a small filled square, maybe 1.5", and run it with the same settings as the test program. About 1/2 way through, do the Speed change thing. Wait for 4-5 passes and then set it back.
When it finishes, copy the entire Console window contents and paste it in a Reply. We are looking for the actual commands sent when the speed change is commanded.
will get back to you soon i hope, bad gaames by chicago bears and maybe lost our quarterback. itll be a while before i get home. happy rest of your weekend!
kind sir, i can see all the gcode in the console after i press see all but the move tab disappears, rather it reverts to original tab.i cannot make any changes? and the autoscroll is going the whole time. i cannot pause it. i need to look at my setting to figure out how to cofig this operation, back soon.
if i make a square with fill it does the same thing. the move controls revert to original move tab.
if i use checkerboard it will let me do the correct procedure but my character count is too big for entering in reply, at least thats what i thought you wanted(?)
i can break in half into 2 replies if thats wanted? i moved it into text file but for some reason it sez 0kb
