I have never had this issue. I have not used the software for a couple of weeks. I fired it up and started my first project. I used Imag-R to set up a photo for engraving which I have done many times over the past several years. Got it downloaded and set up to engrave. It stops before it even atempts to engrave and the console says there is a G code issue. I re downloaded it and I had the same issue. I went back and tried to do a project that had already been finished and delivered. I had the exact same problem. I have savd the console information and can provide it if needed. any help would be greatly appreciated
Go ahead and post the console output; not much to go on otherwise.
Ditto.
Did you accidentally turn on the Enable Gcode Clustering switch?
Are you seeing any error message reported in the Console window?
