need help to work this alignment out, it is good in the software window in Lightburn but it is off on some places in the finished burn, (pics added) The windows and doors cutouts not lined up
Looks like something moved during burn.
it returned to the proper origin at the end of the run was lined up where it should be plus wood was anchored to prevent moving no loose machine parts either and because it returned to the same start point it didn’t skip steps
This may be a symptom of the Ruida Skewed Engraving
problem due to an incorrect PWM Rising Edge Valid
configuration:
As a general rule, both PWM Rising Edge Valid
switches should be set to False
