This maybe a noob issue (i tried to find on forum, but couldn’t). I’m setting up a series of primitive Hexagon shapes (I’ve done hex shapes before without issue.) to create a test pattern with various power/speed samples. for these shapes, it will draw a side, but it seems the last mm the laser cuts drops out (similar to a CNC tab) and the head makes some precise movements. then when it goes to the vertices, it starts great and burns the line perfectly until the corner. I’ve tried converting the shapes to paths and run “close gaps.” i’ve zoomed in to max and there is no gap in the corners. This issue is consistent across all speeds and power levels for this pattern. I’ve saved and rebooted lightburn & rebooted the laser.
UPDATE: I created a single hex and it cut perfectly. I then did “create array” and am able to replicate the issue.
(Ruida 644xg - 80w chinese - lightburn 0.9.11)
