Issue with Window Sizing
Hi everyone!
I recently purchased a new laptop for my laser and have been dealing with an issue. The windows on the right are overlapping to the extent where I can’t adjust the power/speed settings. The issue seems to be that the window is too wide? It won’t let me adjust it. And when I adjust the vertical to fit the power/speed settings it works until I click on anything to change the power/speed/layers/etc.
Any ideas on how to fix?
You could click “reset to default layout” in the window tab at the top. Or you could try to drag the window out of the docking position and then re dock it.
Hi Jeff! I tried resetting it to the default layout. But now I can’t get 2 windows on top of each other.
Click and hold the cuts/layers window by the red bar and drag it into the work area. Drag it back till it snaps into place again. Both pictures look the same.
This video should help.
