Having a difficult time calibrating the 8mp 95deg camera.
The camera is installed on a 900x600 bed at about 32” above the bed. Door open position.
Initially tried calibrating using standard lens. Was able to get good scores (.12-.19) but after the camera alignment step, the image was a bit distorted and the absolute coordinates were extremely off. So ran the wizard again using fisheye. Not getting any good readings, if I can get .40 score I’m lucky. It is so inconsistent with the readings typically above 1.1 score.
On a side note several times received a score of “nan great!”
The last camera I had installed was a 120deg 5mp ELP and it was rather close with absolute coordinates. Thought I would upgrade to the 8mp but so far not working out.
I’ve just installed one of these and run through the calibration and alignment, and it wasn’t particularly hard. Things I noticed when doing so:
Don’t use the fisheye setting - it’s not a fisheye lens
The dots pattern might need to be closer to the camera than with the 5mp to get good capture scores.
If you accidentally back out of the ‘Camera Alignment’ window, make sure you re-enter the same scale on the 2nd time through - I’m fixing this in the code so it remembers the number. At present, it does not, and this catches quite a few people off guard. I did this myself by bumping the Esc key - had I not known about the scale issue, this probably would’ve tripped me up too.
Fisheye lenses require you to angle it a bit, but non-distorting lenses need it to be flat. I’m working on improving the images used to show this a bit better. Glad you got it working.
