I was using light burn with no issues at all. I upgraded my Xcarve to add new motors and add the riser, From that moment on I can not get the machine to behave at al. I use J Tech 7w plus with the e carve. in easel (the program that runs the router, It moves perfectly. When I try in light burn it starts to move then stops. Then moved back to where I was starting. This is happening with both X and y moving left and forward. Again, this does not happen with Easel.
I was using the 1.7 then upgraded to the latest. Both versions do the sames thing.
Take a close look at your setting in Easel and make sure there are no differences in LightBurn.
If the machine is behaving well then your motor transplant is likely fine.
Has your origin or working size changed in LB ?
What do you mean by “both versions”…1.7.08 and 2.0.02?
If the issue is only happening in 2.0.02? then please try the latest Public Release Candidate v2.0.03 RC2, as there have been some very recent patches for negative coordinate machines that had jogging issues after the 2.0 upgrade.
Sorry for the delay in responding. I was on a cruise
I found the fix. I uninstalled light burn completely and reinstalled. Works perfectly now! Thanks.
