# Issues with LB V2.0 Laser moving to 0,0 after every cut. XTool D1 Pro 20W
**URL:** <https://forum.lightburnsoftware.com/t/issues-with-lb-v2-0-laser-moving-to-0-0-after-every-cut-xtool-d1-pro-20w/175191>\
**Tags:** limits, version, xtool-d1, xtool\
**Created:** [July 11, 2025, 3:17pm UTC](https://forum.lightburnsoftware.com/t/issues-with-lb-v2-0-laser-moving-to-0-0-after-every-cut-xtool-d1-pro-20w/175191 "2025-07-11T15:17:54Z")\
**Showing post:** 3
**Author:** ![misken](https://forum.lightburnsoftware.com/user_avatar/forum.lightburnsoftware.com/misken/32/47593_2.png) [@misken](https://forum.lightburnsoftware.com/u/misken)\
**Post date:** [July 11, 2025, 3:30pm UTC](https://forum.lightburnsoftware.com/t/issues-with-lb-v2-0-laser-moving-to-0-0-after-every-cut-xtool-d1-pro-20w/175191/3 "2025-07-11T15:30:06Z")
Edit: Adam was typing faster than me 😉
> [@gregw66](#):
> I’ve seen others with similar problems. The only solutions I’ve seen is to go back to an old version. Which I did and now everything is working after losing an hour of my time. OR a bunch of GCode tinkering. Now I know GCode from 3D printing and I’m used to tinkering with my Ender 3 because it is open source. I am not willing to tinker with it on software I pay a yearly license for. So, please, let’s fix this and why would you not test the software on a very common laser such as the D1 Pro?
It seems you didn’t really read the posts of the others. This issue is caused by a bug of importing the settings from the old version to the new one. A very simple fix is to remove the settings / laser devices and just add them again. This worked for everyone so far. Not going back to the old version.
> [@Laser moves diagonal after every cut](https://forum.lightburnsoftware.com/t/laser-moves-diagonal-after-every-cut/174829):
> I just installed the latest update. I did not change any setting from the previous version. Now after every cut, every engraving the laser moves diagonal towards bottom left for about 15 mm… 2 secs, (sometimes up to 6 seconds travel before it goes back to burning). When engraving 200 + lines I loose 400 seconds of work time. Just annoyed at this useless move which was not there before. Any idea what the cause can be? Made a clip but can’t upload it here. Now a simple 1.5 min project to en…
Another remark: xTool is not supported very well by LB because xTool is not interested. They have their own software and hinder the development of full LB support. So it’s not an issue of LB, it’s xTools fault. Let them know you are not satisfied with their level of LB support to make them increase their efforts.
It’s like Apple. If you buy xTool, stay in their ecosystem. If you want full LB support, don’t buy xTool.
_[View the full topic](https://forum.lightburnsoftware.com/t/issues-with-lb-v2-0-laser-moving-to-0-0-after-every-cut-xtool-d1-pro-20w/175191)._
