I’ve been trying to wrap my head around an issue I’m having, I’m new to Lightburn so odds are it is something easy I’m overlooking.
I have a snapmaker 2.0 A350. I have added it manually on 2 different computers. 1 is connected to the SM via USB the other is “offline”. I havent figured out how to get the one that is connected via USB configured properly so i have tried save to gcode on both with the same results on both.
I have imported a 4"x4" image into LB (I’ve tried multiple different ones) After I adjust all of the settings in LB I save to gcode. When I open the gcode in Luban (the SM software) to send the file to the SM via wifi the resulting “print” is about 1/2 the size of the imported image. The file size of the gcode created in LB is also about 1/4 the size of a gcode file created with the same image in Luban.
Not sure what other info might be needed but happy to provide
