Hey there, new here so I’m sorry if I’m missing something out of stupidity!
I’ve set up LightBurn for my Shapeoko Standard 3, I’ve reversed the direction too, the issue I am having is that if I home my CNC then click “Show Last Position” it lines up with the top right of the work space grid, but if I go down to my bottom left corner where I have set my origin, the origin is above the bottom left
I can’t resize my “Working Size” as it adds or subtracts from the left of the grid or the top of the grid, I can’t figure out how to have my origin be the very bottom left of the work space
Reduce the height of the workspace - the position of your laser is relative to the home location, so you’ll end up “pulling up” the bottom of the page by doing that. You’ll have a macro set to move the origin offset by a specific amount, and that should match what your workspace size is.
It’s going to take it off the top, you’re correct, but your machine homes to a fixed point, and the distance from there to the origin is a set amount. You might have to shift your designs down a little, but it’ll fix the physical misalignment between the two spaces.
