it leaves a line
Hello, I have Windows 11 and my laser printer is an Omtech 2440. When I move the print head from the source to the object I want to print, it leaves a line. I can print it, but it leaves another line when I return to the home screen, and sometimes the print job gets ruined. Can anyone help me?
What does your preview look like? Can you upload an example file (with the problem) here?
When a CO₂ laser tube fires when it should be moving, that generally indicates the high voltage power supply is failing:
If that is not what your machine is doing, the items @bernd.dk suggested, plus photos of the mis-burned material will help identify the problem.
My machine is an Omtech 2440, and this is the line I’m referring to.
For example, to make a square, as the laser moves, it burns all the wood.
Without a photo and the lbrn2 file, it’s difficult to tell what’s happening.
If the square is completely filled, then the layer is probably set to Fill.
