A warm hello to everyone,
I have only been working with laser technology for a few months and I am in the process of building a laser. I learned to appreciate Lightburn very quickly. There are many possibilities. I work with a MKS DLC controller V2 and GRBL1.1h.
First a question: Can I start a job without having to connect the laser, only with the controller as a test with lightburn?
In lightburn I created a simple ellypse as a test and generated it as G code. I have included an excerpt from the G-Code.
But now to my problem. I always get an error message:
Project loaded in 0 milliseconds
Stream wird gestartet
Layer C00 Pass 1 of 3
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
Auf oder in der Nähe der Linie 5:
Job halted
Stream fertiggestellt in 0:00
[MSG:Reset to continue]
ok
Grbl 1.1e [’$’ for help]
[MSG:’$H’|’$X’ to unlock]
[MSG:Caution: Unlocked]
ok
; LightBurn 0.9.20
; GRBL device profile, absolute coords
; Bounds: X24.94 Y22.88 to X114.94 Y111.2
G00 G17 G40 G21 G54
G90
M4
; Cut @ 10 mm/sec, 80% power
M9**
G0X44.78Y30.42
G0Z2
; Layer C00 Pass 1 of 3
G1X43.89Y31.02S800F600
G1X43.02Y31.65
G1X42.16Y32.3
G1X41.32Y32.96
G1X40.49Y33.65
I’ve tried quite a bit, but haven’t found a solution.
At first I had negative coordinates, which I could then correct with the offset command: G10 L2 P1 X-430 Y-310. The homing position detection works very well. The frame positioning is ok. Manual positioning also works exactly. So it can’t be because of the coordinates. I read about a similar problem in the forum, but couldn’t find a solution. Maybe it’s a simple thing that I overlooked as a newbie.
I would be very grateful for any help, as I can’t get any further.
