I have an Ortur LM2 with the upgraded Neje Module. I keep getting very jagged lines. Seems to be happening at app speeds. Any recommendations?
in this image i can’t guess in what axis you have the issue so… check your belts in X and Y
The top of the letters and top of the T are parallel with the x axis.
so you have an issue on that belt, check it and check also that the pulley is not loosen on the motor shaft
