Job (object) placement when opening files. Creating jigs
**Job (object) placement when opening files.
I am running an xtool d1 pro extended 40 watt.
I am trying to make jig files so I can batch run product and be reapable. IE shut down the system come back later and reload the file place product in a preset templet and repeat jobs with accuracy from home position.
I create the template save the file and when I reopen the file in lightburn, it places the templet objects to the center of the work area and not to where I had placed them when saving the file. I have tried setting the origins to all the different settings, setting home to x1 y1 so if the limit switches are the problem.
Is there a setting in lightburn I am missing? Am I not following a set procedure. I also must push the home button twice to get the laser return to home.
Thank you all for your time and effort in helping me resolve this issue.
Richard
The homing issue will be that $131 has not been updated for the extension, some sample pic will help with the other issue.
