hi all, need some help, when i start a job it stops half way through,in the console it says stream ended but the job hadnt finished its happened a few times today now, im running lightburn 9.04 i have a k40 with cohesion mini board and running it on windows 7 64bit, would be greatful of any advise thanks.
Start with these:
Also make sure your C3D board is properly grounded, as is the machine itself. Grounding issues and power noise are the two biggest things that cause resets on C3D boards.
Thanks I will give that a go.
