Hi, Paul here from Ireland. Looking some help. I use an atomstack s20 pro on a Win11dell laptop running Lightburn 1.7. Every thing has been fine so far but II think I have hit some button which is causing my framing to become erratic. It is most noticeable in the MOVE window. (3 x 3 arrow ARRAY).
If I jog the top middle arrow the laser moves a step northward, and if pressed again takes another step northwards.
Simerly, If I jog the bottom middle arrow the laser moves a step southward, and if pressed again takes another step southwards. All done silently
However, If I jog the middle right arrow the laser moves a step to the right (eastward), BUT if pressed again takes a step backwards to the west accompanied by a noisy vibration.
If I jog the middle left arrow the laser moves a step westward, and if pressed again takes a step eastwards. More vibration
When I look at top of MOVE my move to position for x co-ord is positive and y c-ord is negative, I suspect some direction has flipped. I sent the laser back to origin and it went in opposite direction.
O 0 0
0 0 0
X 0 0
My coord system is shown by the X and X and Y increases the further you move away from origin. See arrows fig 1However now (as far as I can tell) Y value still increases the further from origin but X now increases as you come closer to origin fig 2.
fig 1
Fig 2
I would appreciate any help
Paul
Message below
Stream completed in 0:00
Starting stream
error:20
Unsupported or invalid g-code command found in block.
On or near line 0:
[MSG:Program End]
ok
<Idle|MPos:40.000,30.000,0.000|FS:0,0|Pn:P|WCO:0.000,0.000,0.000>
ok
Starting stream
[MSG:Program End]
<Idle|MPos:30.000,30.000,0.000|FS:0,0|Pn:P|WCO:0.000,0.000,0.000>
ok
Starting stream
[MSG:Program End]
<Idle|MPos:20.000,30.000,0.000|FS:0,0|Pn:P|WCO:0.000,0.000,0.000>
ok
Starting stream
[MSG:Program End]
