Join two lines to make one but without group?
How can I join A to B to make one line without using group. Either with or without the little tail at the top of A. I just can’t seem to work out how to do this in Lightburn so would appreciate some guidance - or is it just not possible?
Basically, you can’t.
By definition, a path consists of vectors joined by nodes. Each node sits between at most two vectors, so you cannot have a T intersection with three vectors meeting at a node.
What you can do is use the Node Editor to trim the vertical line where it meets the horizontal line. Then you group the two lines into a single unit that you can move around as needed.
Ok, thanks for the clarification. Saves me keep hunting how to do it LOL! Thanks :smiley_cat:
