JTech Photonic Pro USB connection not work
I have a new JTech Photonic Pro I am trying to connect to with Latest Light burn, it recognizes USB Com3 but does not connect to laser cutter. I have tried re-installing usb drivers,
Hi,
have you set the correct port in Lightburn? Also have you tried restarting lightburn? What operating system are you working on?
I got it working thank you!
Problem was the E-stop was depressed and I did not know. Lightburn will not connect to Jtech with that depressed.
What worked.
  1. Ensure E-stop is not depressed.
  2. Plug in Jtech and turn on before starting LightBurn
  3. Start Light Burn and go through setup per Jtech Instructions.
Thank you Julez for answering my post.
Dan
glad you got it working! happy cutting
