Hey guys,
need your help with my K40 (with Mini Gerbil Board)
Limit Switches are in the upper left.
To use Lightburn I have to set $3=3 and $23=3 to have the right direction of movement and homing to the upper left edges.
If I want use my K40 with LaserWeb I have to set $3=1 to get the right way of movement. With $3=3 the movement in the y-axis is diversed. I experimented with the $3 and $23 values to get common values, because some projects are better to work in LaserWeb and some in Lightburn.
Can I set up something in the Softwares to get a right way of direction with same $-values or do I have to setup the right values before every use in each software?
Hope I can explain my problem right. Sorry for my school-english (it is some years ago)
thanks for your help
If it helps here are my $-values for Lightburn:
$0=10
$1=255
$2=0
$3=3
$4=0
$5=1
$6=0
$7=0
(ATC M6, pulse/ff)
$8=100
(ATC Tool Td, milliseconds)
$9=100
(ATC M6 Td, milliseconds)
$10=1
$11=0.010
$12=0.002
$13=0
$19=0
(Softstart, milliseconds)
$20=0
$21=0
$22=1
$23=3
$24=2000.000
$25=2000.000
$26=250
$27=4.000
$28=5
(Spindle freq. 0 to 15)
$30=1000
$31=1
$32=1
$100=158.000
(x:stp/mm)
$101=158.000
(y:stp/mm)
$102=160.000
(z:stp/mm)
$103=160.000
(a:stp/mm)
$104=160.000
(b:stp/mm)
$110=5000.000
(x:mm/min)
$111=5000.000
(y:mm/min)
$112=5000.000
(z:mm/min)
$113=5000.000
(a:mm/min)
$114=5000.000
(b:mm/min)
$120=5000.000
(x:mm/s^2)
$121=3000.000
(y:mm/s^2)
$122=3000.000
(z:mm/s^2)
$123=3000.000
(a:mm/s^2)
$124=3000.000
(b:mm/s^2)
$130=320.000
(x:mm max)
$131=230.000
(y:mm max)
$132=200.000
(z:mm max)
$133=200.000
(a:mm max)
$134=200.000
(b:mm max)
