I set my lightburn to 400 mm S but is going so slow when doing a image how do I set the speed other than in cut
If you are trying to run an image using Smoothieware, it has a throughput limit with GCode - it generally won’t raster engrave faster than about 80mm/sec with the default DPI setting.
GRBL-LPC firmware will go faster, but 400mm/sec is likely faster than your power supply will accurately fire anyway. Even with GRBL-LPC I wouldn’t recommend going above 250 mm/sec.
Mine is just a stock k40 with C3D smoothie
What’s the best dpi I can get with lightburn and c3d
Also with the k40 where do I set the power knob on the k40 to full power???
Probably about 350 DPI (it’s a limit of the beam and lenses you use, not the board or software). Running at that DPI will lower the speed you’re able to go though. We have a version of Smoothieware that I’ve modified to improve the handling of raster data for the C3D. We’re still testing it, but the initial results are quite promising. I would expect to see that come out within the next few weeks or so.
