K40 Whisperer vs Lightburn - mm/s
Am I crazy? Switched from K40 Whisperer to Lightburn. Both are set to mm/s. Somehow 40 mm/s is WAY faster in K40 than Lightburn. Lightburn is crawling and I end up with scorched earth. Am I doing something wrong?
Perhaps LightBurn is set to mm/min, which would reduce the speed by a factor of 60.
I know you know what you clicked, but check it again just to be sure. :grin:
Did this switch came with a Controller change too
Nano to GRBL?
