K40 with Cohesion Controller using Lightburn export cannot find file in play menus
Hello
I have a K-40 with a cohesion controller attached to the Cohesion External Display. I am using Lightburn Software I Generate the Gcode by selecting the " Save as Gcode " button. I then save the file into a SD card. I can see that it is saved as Gcode. I eject the disk and insert it into the cohesion controller remote port. I select plat then SD card and it shows a message “System Volume Info” I select it and there is nothing showing at all no files to select just an empty screen. I have had this setup for quite some time and I have never gotten it to work. Thanks in advance for any help.
