Kamera einrichten
Hallo hoffe auf Hilfe ich habe einen großen Laser 2500mm x 1300mm
und möchte nur einen rechten Bereich ca.1000mm x 1300mm abdecken aber der Assistent möchte ja
immer in der Mitte Kalibrieren wie kann ich vorgehen
Based on my understanding of the camera alignment process I don’t think what you’re trying to do is possible.
If you were able to capture the target markers on the far left side of the camera image that might allow you to only have an image capture between the middle to right sides of the machine.
I will try to cheat the system in that I will change the machine bed size in the basic settings, mark that part of the machine bed with a piece of tape and run the entire adjustment process in this part of the bed. When you have a camera profile, you can set the machine back to the correct size.
It’s worth a test - but no guarantee :wink:
Hat leider nicht funktioniert da das Kamera Bild von Lightburn beschnitten wir.
Too bad, but it was worth a shot.
…it may be that a member from the LB staff is looking into the matter
