Keine Kalibrierung? (No calibration?)
I want to determine the camera position and I have laid out a sheet 20 × 20 and when I want to read it it only makes the frame on the bottom left for testing and not around the whole sheet?
Can it be because I have the trial version for 30 days?
Fehler gefunden falsche Arbeitsbereich eingestellt
Error found wrong workspace set
The trial version is identical to the full version. There is no difference in the implementation.
Glad you found the issue. Thank you for sharing your findings.
Yes Trail Version
