Kerf offset issue
Having a strange issue with kerf offset, when using a positive number in the offset say 0.05 on a box joint type shape (closed btw and 100% sure of it) the box joint is kinda loose, as I increase the kerf amount to say 0.1 It’s getting looser, 0.3 even looser, yet when i look into the preview window I can clearly see that the shapes are overlapping each other the higher I go.
What’s going on ?
Thanks
That’s odd.
Can you post a LBRN file that exhibits that behavior so we can have a look. ?
What is the measured kerf of your material?
… it’s not easy to help here.
People, if you have found a solution to your problem or your question yourself, let us know. It should be usually polite behavior.
