Kerf Visualisation
By selecting Kerf Offset the result appears to be invisible until cut.
In order to visualise the result before burning, would the shape Offset function achieve the same thing?
Obviously selecting “Inward and Corner” for negative Kerf?
When you view the preview it does show the adjusted kerf. It does not show it on the work screen though. Offset function might work as you said to give you a better visual before cutting
The offset function is what’s used to produce the kerf, so yes, that will work.
Thanks guys. That’s great to know.
