Hello,
LB 1.0.06 can move Z axis in Ruida KT332n in movement panel; LB knows Z height too, but offset it doesnt work in layer or in focus test. I belive machine wait por U axis instead Z.
is there a way to solve it?
thanks
Hello,
thanks
hi i am looking for the same answers as you but seems nobody is willing to wade in with any useful answers
I think there are not many who have this controller and or use the Z axis, me for example. I also have a KT332N, am very happy with it, but I have no Z axis. It has nothing to do with âwillingâ.
Iâm no Ruida expert but I believe this hasnât been âbuilt-outâ yet.
I understand that there is some kind of entanglement between U-axis and Z-axis that is (as of yet) unresolved.
Hi my apologies for using the word âwillingâ my mistake
Do you mean lightburn have not factored in that some controllers are using u axis rather than the normal z axis like most people.
Do you think it will eventually be able to choose either z or u in the furtureâŚ
Any thoughrs
For the offset and steps per offset function i mean as the rest of the controls seem to work as normal
Thanks
We have a task on our list to try to make this controller use the U axis movement commands instead of Z, but itâs going to take some time to work through. I donât have a machine here with this controller in it that has a motorized Z, and itâs possible that the controller doesnât have relative U axis move commands - I need to see if this command is allowed.
If you need my help I have one and I offer to your tests.
thanks
Iâve run a quick test just with the controller itself and what I think is a valid candidate for a U axis move command and it seems to work. If you never attempt a Z axis move it wonât try it, so itâs safe to include for the next release.
that is great news to hear that would make things so much easier when doing some projects and for de focusing when doing multiple passes etc etc
thanks very much for coming up with a solution and making lightburn worth it weight in gold keep up the amazing work you all do for the laser communityâŚ
Just a question i did not see this in the latest release was it added or will it be in the next release thanks for your time
Gary
hi i know you are busy but did you manage to sort the z offset for the u function ???
Happy to report that it works! version 1.1.03 moves the Z axis (or U) for the layers with the Z offset !!
Thank you so much! I really needed this so I can cut and do line text with a single file or do multi-pass cuts on thick stock
hi there Andrew
once i set my autofocus for the material i can get the z offset to go down but cannot get it to go up say 2mm to cut deeper into the wood.
not sure if i am doing something wrong here i am guessing because i is already at zero on the focus it wont allow me to go beyond that but is there a way to achieve this any help would be great
Gary
